Re: Hey Bob M, and oher electrical gurus!
Posted by Bob M on August 30, 2004 at 11:17:45 from (165.170.128.65):
In Reply to: Hey Bob M, and oher electrical gurus! posted by Steve W (NY) on August 30, 2004 at 10:34:52:
Hi Steve - You've understand/describe perfectly how the BN charging system is supposed to work! With that aside, there's several possibilities why the generator won't doesn't charge in the "low" setting: Light switch field resistor is bad (open); there's a problem in the light switch (doesn't ground thru the field resistor in the L position); the switch/mounting bracket is not grounded (fresh paint is insulating mating parts). Could also be the ammeter simply won't read the 2 - 3 amps going thru it in the low charge position (check across the battery with an accurate voltmeter - anything higher than 6.5 volts means the battery IS taking a charge). However if you only run the tractor for short periods (i.e. not hours on end at full speed) the battery will be fine charging on high all the time. Or you can dispense with the manual control by replacing the cutout with a voltage regulator for a later model 6 volt Farmall. Not 100% original, but it will be better for the battery over the long haul. Hope this helps, and save mid- to late-August 2005 bot bring your BN to the Churchville and Hamlin shows!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
