Re: Farmall C distributor - timing
Posted by captaink on August 31, 2004 at 06:03:10 from (66.115.212.249):
In Reply to: Farmall C distributor - timing posted by DWW on August 31, 2004 at 05:26:28:
One thing to check is the rubbing block on the points. As that wears, the timing will retard and if severe enough may cause the symptoms you describe. Put in a new set of points & condenser (I always do both to prevent problems) while you have it apart.
Your distributor may also be worn, while you have the cap off, grab the shaft and see how much play is there. Since the timing on a C is all gear driven, the only other thing I can think of (others may have more) that could cause your symptoms would be if a gear is wearing and jumping over.
Good luck!
Post a Followup
Subject:
