Re: Farmall H fan belt adjustable pully
Posted by Wayne Swenson on September 01, 2004 at 19:58:00 from (66.191.70.31):
In Reply to: Farmall H fan belt adjustable pully posted by John in Ct. on September 01, 2004 at 15:42:58:
If you have an air compressor & air hammer, use a 1/2" flat punch to get things moving. Some heat & lube will help. Just apply pressure on the raised portions of the movable flange.
Post a Followup
Subject:
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
