Re: Measuring RPM on a Magneto Tractor
Posted by Wayne Swenson on September 01, 2004 at 20:05:54 from (66.191.70.31):
In Reply to: Measuring RPM on a Magneto Tractor posted by Steve W (NY) on September 01, 2004 at 11:34:35:
Simplest method I know is to use a hand held tach that you hold against the PTO or belt pulley.
Do the ratio calculations to see if your engine is up to "snuff"
If my memory serves, about 585 pto rpm is what an H runs when wide open & no load. Should run 540 pto when loaded down on a dyno.
The little Vibra-Tach works ok also.
Post a Followup
Subject:
