Re: Super C Valve Clearance Cold
Posted by BillWV on September 02, 2004 at 09:35:18 from (129.71.139.48):
In Reply to: Re: Super C Valve Clearance Cold posted by JBlavl on September 01, 2004 at 08:40:09:
I"ve heard of two other ways to use feeler gauges.
One is to set a micrometer to the correct setting (in this case .017) and then practice with your feeler gauge to get the feel for it.
Another is to use the "go-no go" method. Bracket the desired thickness above and below; in this case, .016 and .018. Set the valve clearance so that it is loose on the .016 but the .018 won"t go.
Good luck,
Bill
Post a Followup
Subject:
