Farmall Tractors Discussion Board
Re: Power steering problem with M
Posted by GeezerMn on November 10, 1999 at 08:59:44 from (216.161.105.27):
In Reply to: Power steering problem with M posted by Rich Dahlke on November 09, 1999 at 18:05:43:
Check belts.A good pump should stall and slip
a tight belt when steering is turned to limits
left & right.
It sounds like you have a steering gear problem.A scuffed-galled worm and wheel in steering case or ball brg. on end of shaft will
cause this.Remove worm shaft,clean&check. These
aftermarket units worked very good and were put
on many makes of tractors.
Post a Followup
: Re: Re: Power steering problem with M
