Re: I got my Farmall H fan belt flange to move, Th
Posted by John in Ct. on September 03, 2004 at 19:54:22 from (192.233.162.169):
In Reply to: Re: I got my Farmall H fan belt flange to move, Th posted by Dave in CT on September 03, 2004 at 09:06:42:
I sprayed the set screw and nut with PB blaster for a few days. I was able to get the nut off but not the set screw out, I was afraid of breaking the set screw. Next I found the same size nut and put 2 nuts on the set screw. I backed the first nut into the second nut with a wrench, had someone also at the same time use a ratchet with a screw driver bit in the slot turning the set screw too and was able to get the screw out. Next I cut the fan belt off and sprayed down the set screw hole and both sides of the pulley flange with PB Blaster. I sprayed it a lot. I also would tap the flange (Unscrew direction) with a brass punch while holding the fan. I did this every day since Sunday and nothing moved at all until yesterday. It moved a little in the morning. I then sprayed it more and came back later and tapped it a little more. Once it moved I knew it would eventially move. Finally last night I was able to brake it free, now you could almost spin it with your fingers. I didn't put the belt on yet. I also at the same time am resealing the engine (The main job). I have the valve cover off, push rod cover off, oil filter housing off, mag off, pan off etc. I am cleanig out sludge. The fan belt is just a fill in job. The key is to spray it, tap a little with a brass punch, stop, let it sit ,then do it a few hours later. I think you asked once where I am in Ct, I am in Colchester.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
