Re: radiator drain plugged - '51 M
Posted by Wayne Swenson on September 06, 2004 at 13:40:15 from (66.191.70.31):
In Reply to: radiator drain plugged - '51 M posted by Kevin Brooks on September 06, 2004 at 11:19:59:
You remove the steering shaft, not the column.
Take out the large cast nut in front of the shaft & disconnect the shaft at the universal joint. Clean the shaft and smooth the joint end so it will not cut the seal on the way out. It's full length has to pass through the seal & bushing on its way out the front. Good idea to replace the seal when the shaft is out.
Post a Followup
Subject:
