Re: 1466 MFD Value
Posted by Hugh MacKay on September 06, 2004 at 18:38:28 from (216.208.58.105):
In Reply to: 1466 MFD Value posted by darby on September 06, 2004 at 17:50:16:
darby: It was an option although I'm not sure it was built by IH. It should have been on all 1066 and 1466. There just isn't enough rubber on the rear to put all that horsepower on the ground. If you put duals on them, it beats the conventional wide front to bits. Under heavy load duals want to make tractor go straight ahead, the MFD will eliminate that problem. I think there may have been other aftermarket MFD that could be fitted to that tractor.
That was the experience I had with a new two wheel drive 1066 close to 30 years ago. Bough it single, went to duals, then beat the crap out of brakes and wide front turning with heavy loads.
I have since operated big tractors like that with duals and front drive, what a difference it makes.
Post a Followup
Subject:
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
