Re: Farmall 300 hydraulic schematic
Posted by Hugh MacKay on September 06, 2004 at 18:49:44 from (216.208.58.105):
In Reply to: Farmall 300 hydraulic schematic posted by Dick Davis on September 06, 2004 at 16:54:34:
Dick: It's been quite a few years, but I have had both 300 and 560 valve banks out. If my memory servces me correctly there are O rings only in between each valve, the end cap has a gasket. Those bolts you see at end cap go through all valves. There are also just O rings on manifolds going to outlets. Other than it is a miserable spot to work in, the fix is relatively easy.
Post a Followup
Subject:
