Re: Farmall B with no oil pressure
Posted by El Toro on September 07, 2004 at 16:33:00 from (170.224.224.90):
In Reply to: Farmall B with no oil pressure posted by Martin on September 07, 2004 at 14:14:44:
Hi Martin, Remove the old gauge and install a new one or a gauge you know is working. If you still see no oil pressure, drop the pan and the pump. Check for blockage over the oil pump screen
and if that is clear set the pump in a pan with clean oil and see if it pumps oil when you spin
it. If it doesn't pump I would replace it. I would only run the engine at an idle to check that
gauge, you do not want to damage the bearings or
crankshaft. Good Luck, Hal
Post a Followup
Subject:
