Re: FARMALL SUPER A - RIGHT ANGLE PTO
Posted by Jim Becker on September 07, 2004 at 21:28:14 from (4.29.47.118):
In Reply to: FARMALL SUPER A - RIGHT ANGLE PTO posted by NICK on September 07, 2004 at 06:21:59:
The A PTO changed at 66671. After that, it will interchange with the Super A. The earlier unit can be used if you take the entire PTO unit (except the shifting sleeve, which is different from A to Super A). Without checking some part numbers, I am not sure if some of the later 2xx series will completely interchange (may be some gear ratio differences).
When you get the pulley attachment off of a junk tractor, don't just pull the 4 bolts and take what comes with it. You have to get the bevel gear (and probably some hardware parts) off of the upper PTO shaft. It would be easier to get the whole PTO if you can get it for a good price.
Post a Followup
Subject:
