Re: Resistance?
Posted by rustyfarmall on September 09, 2004 at 09:16:03 from (199.120.81.211):
In Reply to: Resistance? posted by Phil from Maryland on September 09, 2004 at 07:32:04:
I can't really answer your question but I had similar problems with my 12 volt conversion M. I solved the problem by purchasing a new 12 volt coil with internal resistor. Around $20 from my napa dealer. Problem solved.
Post a Followup
Subject:
