Re: Resistance?
Posted by Bob M on September 09, 2004 at 10:31:13 from (165.170.128.66):
In Reply to: Resistance? posted by Phil from Maryland on September 09, 2004 at 07:32:04:
Phil - Ballast resistor resistance varies somewhat with temperature. I figure anything between about 2.5 and 4 ohms means the resistor is OK. A reading greater than 4 ohms - especially when cold - would make the resistor suspect. Quick way to tell if the resistor is working? It should get too hot to touch after running several minutes. If it remains cold it's shorted. (Also a shorted resistor causes the coil to heat up and the points to burn out quickly) Another test is with the engine stopped, the points closed and the ignition switch on you should read about 6 volts across the resistor and 6 volts across the coil primary. It's tough assess the condition of a coil with a multimeter. Depending on the coil the primary should read between about 2 and 4 ohms, and secondary between 1,000 and 5,000 ohms. But a coil can show acceptable resistance readings and still develop a weak or no spark. Better approach is to swap it with a known good coil.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
