Re: Axle play
Posted by CNKS on September 09, 2004 at 19:16:47 from (207.178.99.145):
In Reply to: Re: Axle play posted by NDS on September 09, 2004 at 18:14:28:
Thank you. Going to replace both bearings on one side then check the other one.
Post a Followup
Subject:
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
