Re: Axle play
Posted by lee on September 09, 2004 at 21:27:27 from (24.24.95.246):
In Reply to: Re: Axle play posted by CNKS on September 09, 2004 at 17:57:05:
modern ball bearings are made with a built in radial (interference) pre-load. If the bearing is loose radially it will be destroyed in short order with the load it sees. The outer axle bearing is rather heavily loaded. The inner bearing may be OK. Somewhere around $100 sounds about right for the outer. The inner is a smaller bearing. I would avoid a chinese bearing but Japanese or American suppliers are fine.
Post a Followup
Subject:
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
