Re: I need advice on cracked block
Posted by Sam in NJ on September 10, 2004 at 07:19:48 from (216.83.107.2):
In Reply to: I need advice on cracked block posted by Jrry on September 07, 2004 at 04:30:53:
Jrry,
If you have coolant in the cylinders, it is most likely coming in through a bad head gasket. Since that is a wet-sleeve engine, a cracked block will usually only leak on the outside.
As far as repairing it goes, I've heard that they can be welded, but good luck finding someone who will work on it. Nobody seems to want to touch old stuff anymore. Your best best to fix it properly would be to find a block that isn't cracked and rebuild it.
Sam
Post a Followup
Subject:
