Re: I really,really hate magnetos!
Posted by lee on September 10, 2004 at 16:06:13 from (24.24.95.246):
In Reply to: I really,really hate magnetos! posted by John M on September 10, 2004 at 14:39:59:
How slow can an impact wrench run? Are you sure the impulse coupling is working? Turn it up by hand or on the tractor try to observe the spark as the impulse coupling trips. It actually sounds like a short but you say you've removed the switch wire and it works on the bench. You say you've verified timing 3 times and I assume you are checking for spark right at the mag coil output.
Post a Followup
Subject:
