Re: What is the L terminal?
Posted by lee on September 12, 2004 at 10:37:32 from (24.24.95.246):
In Reply to: Re: What is the L terminal? posted by ffolkes on September 12, 2004 at 09:50:29:
Yes, it should cut back as it reaches full charge
but let's not worry about what it used to do.
Sounds like ancient history with this tractor not running in some time. Get it wired and running and see what it is doing now. Then go from there. Is the regulator new? Has anyone been inside tweaking it. How about the gen? When was it re-built? If you've got an extra $25 take the gen/reg to a Starter/Generator/Alternator repair shop and have them clean/inspect and adjust it on a bench tester.
Post a Followup
Subject:
