Re: Farmall C pulling 7 foot JD drag bush hog
Posted by Don Mountain on September 12, 2004 at 17:49:14 from (206.31.97.129):
In Reply to: Re: Farmall C pulling 7 foot JD drag bush hog posted by steveormary on September 12, 2004 at 15:05:42:
I pull a 5' brushhog with my Super C Farmal. Its a lot of first gear running to turn it over fast enough to keep the blades unfolded out straight like they should be when mowing. And I have to run at maximum rpm's on the governor to effectively cut with it. And I have to pick it up with the hydraulic hitch in order to keep it running. I think a 7' brush hog would be better with maybe 40 or 50 horses. An M maybe. And if you are cutting any trees, then you are probably going to stall it often. It will be really hard on your tractor. Is your head gasket on tight? And all of your gears in good shape?
Post a Followup
Subject:
