Re: Rear axle seal is leaking on W-4
Posted by el-mar on September 12, 2004 at 18:09:22 from (66.231.125.66):
In Reply to: Rear axle seal is leaking on W-4 posted by Bob Quale on September 12, 2004 at 16:46:48:
restored a W4 a few years ago. replacing rear seals turned into about a 300.00 dollar job. getting the splined wheels off required taking the top off the rear end taking axle out and putting it in a 50 ton press with repeated heating and cooling. also bearings had to be cut off to get it in the press. hope you find an easier way.
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
