Farmall Tractors Discussion Board
Re: Re: Farmall B with A left axle!...plow needs
Posted by moboy on November 11, 1999 at 10:56:02 from (12.14.212.18):
In Reply to: Re: Farmall B with A left axle!...plow needs posted by werf on November 11, 1999 at 09:07:22:
you've got a "narrowed" b. been told that all that is required is to remove the left housing and corresponding axle shaft and everything bolts right up. i've thought about doing that as i have a woods belly mower also. i've used mine for plowing gardens (not very hard work), but for anything heavier i use my ac wd. the plow i use is an old 2 bottom pull type. you need to get an owner's manual, tell you how to narrow up and what implements are best suited. have fun and good luck!
Post a Followup
: Re: Re: Re: Farmall B with A left axle!...plow needs
