Re: Hydraulics on 560 running
Posted by Aces on September 13, 2004 at 10:42:21 from (67.0.37.160):
In Reply to: Hydraulics on 560 running posted by Donny on September 13, 2004 at 06:33:08:
Donny. Captain and Joe are both right, but when you are in the relief and looking at the orifice make sure the unload valve and piston are in good shap and the oring on the piston is good. The 560 has an open center system and the unload valve must un load the system or you have high pressure and it will pull the engine and make the hydraulics very hot.
Post a Followup
Subject:
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
