Re: OT-Ideas for watergate
Posted by Andy Martin on September 13, 2004 at 11:00:31 from (12.74.229.21):
In Reply to: Re: OT-Ideas for watergate posted by rustyfarmall on September 13, 2004 at 09:48:29:
If your stream carries large amounts of debris during flooding, I suggest hanging sheet iron, old roofing material, from the cable. It provides a visual block for cattle and will float as required to let the water through.
If the cable is too high at the point of entry, though, a dirt biker could push aside the sheet metal.
You should count on using four posts. The outside two are for use as deadmen to hold the inside posts up, cable from the bottom of the outside posts to the top if the inside posts.
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
