Re: OT-Ideas for watergate
Posted by 686farmall on September 13, 2004 at 11:43:02 from (207.177.37.240):
In Reply to: OT-Ideas for watergate posted by FC on September 13, 2004 at 09:21:12:
If you have some, use old corrugated roofing sheets. You need to use some pretty heavy cable (we used two electrical overhead ground wires twisted together), and hang the sheets vertically with chain. Use about 5 links to attach each sheet to the next sheet at the mid-point of the sheets.
Beauty of this set up is its too heavy for cattle (or bikers) to just push aside, but flood water pushs it up like a hydroplane. Added plus is that branchs, limbs, old tires, etc, don't get caught (you have to flood pretty high before the chain in the middle catches anything).
Takes some work, but it last forever and works fine. And its just about vandel-proof.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
