Re: Hard starting Super M
Posted by El Toro on September 13, 2004 at 15:14:56 from (66.119.34.39):
In Reply to: Hard starting Super M posted by Ludwig on September 13, 2004 at 12:45:07:
Hi Ludwig, When the tractor does start after several attempts, does it smoke or appear to have been flooded? If it does the float valve in the carburetor may be leaking fuel into the cylinders
causing a flooded condition. A weak coil or condenser may work fine until the engine is warmed up, then cause hard starting until the engine cools off, like overnight.
Cars that had carburetors in the mid 70's had this problem too. Instead of using
brass for the floats they started using a composite material that when it got soaked with gasoline it would sink. The car would usually start ok in the morning when cold and after driving a few miles and then after making a stop, the engine was hard to start. I replaced 3 floats
on diferent cars and this cured the problem.
I think IH used brass floats after they quit using cork, even brass floats can get pin holes. Hal
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
