Re: Farmall Super A rear rims and lift link
Posted by Hugh MacKay on April 03, 2009 at 02:52:30 from (216.208.58.146):
In Reply to: Farmall Super A rear rims and lift link posted by Scott Johnson on April 02, 2009 at 13:14:00:
Scott: You can increase tire sizes, however every tire has printed on sidewall the ideal size rim for that tire. I you do not use that ideal rim size, you will not get maximum traction from that tire. That is true, whether it be SA or a 350 hp articulated.
If the fire got hot enough to burn tires, I doubt if rims are much good anyhow.
