Re: Gas tank - inches to gallons?
Posted by Haas on September 14, 2004 at 18:15:55 from (12.65.66.144):
In Reply to: Gas tank - inches to gallons? posted by Rodger in Sabula on September 14, 2004 at 12:33:27:
Dividing the height by the gallon capacity will give only an approximate result. At lower tank levels, you will have more than the stick says remaining, and at higher levels, the emty space will not be as much as the stick says. If you want accuracy, the only thing to do is empty the tank and then add gasoline a gallon, or 1/2 gallon at a time and record the level each time and mark a stick as you go. Due to the odd shape of the tank, doing an accurate calculation would be quite complicated.
Post a Followup
Subject:
