Re: The Trouble With You Guys Is.....
Posted by K.B.-826 on September 15, 2004 at 20:15:19 from (209.163.30.22):
In Reply to: The Trouble With You Guys Is..... posted by Allan in NE on September 15, 2004 at 14:29:44:
Glad you got it going Allan. Sorry I didn't get back to your post on the 986, been busy. Anyway, the main problem with those shifters, there's just too many moving parts to wear out and get loose. The thing I hate most about them, they are a pain to work on. You need to remove the seat assembly, which is probably right around 100 pounds, and hardly fits over the steering wheel and out the cab door. Once you get that far and try to pull the range trans. cover, the reverse shift fork falls down, since they went to a one-piece shifter shaft. Then you need to drain the oil and fish that fork out. You get the picture, with the 86 series, all they cared about was operator comfort. Anyway, who knows on the engine. Main problem on the 400 series was cavitation, if it was well-maintained, could go way over 10,000.
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
