Re: 460 Hydraulics
Posted by Joe Evans on September 16, 2004 at 19:48:45 from (67.129.216.97):
In Reply to: 460 Hydraulics posted by TGIN on September 16, 2004 at 16:11:34:
Aces has you pointed in the right direction. It is most likely you have a blocked orifice plug and orifice plug screen. The heating you are experiencing is from hydraulic oil being forced through the relief valve.
As for the power steering? Can't explain that--this is a separate circuit with its own pump. However, if you do find that foreign material has blocked the hydraulic system's orifice plug and screen, then foreign material may have found its way into the PS pump. If this has happened, then it could be that crud is fouling the PS circuit, too. There is the possibility that the PS gunk (if any) may be screwing up the PS pump's relief. The PS relief is integral with the PS pump I believe. You will have to access the PS pump to do this obviously. This is very easy to do.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
