Re: How hot to heat crank pulley??
Posted by MN Scott on September 16, 2004 at 20:35:44 from (206.9.216.28):
In Reply to: Re: How hot to heat crank pulley?? posted by RT (seTX) on September 16, 2004 at 20:01:36:
Try to avoid the hammer if you can. When you pound on the pulley you impact the crank againest the main thust bearing. Clean the surfaces with emery cloth and heat and oil as others have said, the treaded rod should pull it on. If it will not go you can use a harmonic balancer installer. They have a one inch treaded shaft with thrust bearing and adapters to fit the crank treads. They will pull any pulley on.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
