Re: Power Outputs
Posted by Bob M on September 17, 2004 at 12:34:49 from (165.170.128.65):
In Reply to: Power Outputs posted by Allan in NE on September 17, 2004 at 09:42:08:
Those old tractors worked indeed Allan!!
Kinda the same deal with a mounted sweet corn picker on our faithful Super M. PTO ran the picker mechanism; the hydraulics operated the cutter lift cylinders and worked the dump cart; and the tractor moved itself, the picker and dump cart (cart weighed 8,000 lb loaded) across the field. Used every one of the tractor’s 44 HP!
Was no picnic for on the operator either. The picker sheet metal funneled engine heat directly back onto the operator - it was brutally hot even in moderate weather. And it was NOISY! Besides the normal exhaust bark, the myriad of chains, the elevator conveyor and blower (with the operator sitting right in the middle) made it deafening. Nor did the tractor have power steering. With an extra an 800 lb or so of picker carried on the fat single front tire, guiding the machine across our gravelly, side hill fields was indeed a “two fisted” job.
However I kinda miss running that outfit now!
Post a Followup
Subject:
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee ... [Read Article]
