Re: HM Hydraulics--again
Posted by CNKS on September 17, 2004 at 19:00:07 from (207.178.99.200):
In Reply to: Re: HM Hydraulics--again posted by Allan in NE on September 17, 2004 at 04:51:46:
I drove an H in the 50's with a vegetable cultivator, as I remember the two front ports were attached to two cylinders on the front section, rear was attached to the rear port on the left side. I tried using a delay valve that screwed into the rear port. Sometimes it worked sometimes not. Without the valve, all sections raised more or less at one time. Used the rear section only quite a bit, without the front section mounted, but don't remember which port we used for that -- one of the left ones, since the cylinder was on the left side. The same front cylinders were used for a semi-mounted 3-disk breaking plow.
Post a Followup
Subject:
