Re: Will the Cub mower fit a 140...my mistake?
Posted by Hugh MacKay on September 18, 2004 at 14:50:54 from (209.226.247.161):
In Reply to: Will the Cub mower fit a 140...my mistake? posted by Sandy on September 18, 2004 at 11:36:29:
Sandy: You have one insurmountable problem and Sam named it but did not elaborate. The two PTO turn opposite directions. The pitman crank screws on the end of shaft. I don't remember about pulley at back but may be the same. If you try turning these opposite direction to that intended pitman crank will screw off the shaft. Just didn't want to see you getting into a fabrication job on mounting and find it a waste.
Post a Followup
Subject:
