Re: the picture
Posted by jfky on September 18, 2004 at 18:00:01 from (67.232.144.130):
In Reply to: the picture posted by vrickster on September 18, 2004 at 17:39:06:
I have a 44 that has an electric start and has been converted to 12 volt. B were made from 39-46 I believe, about 20 hp, none had hydraulics-manifold lifts. Same engine as an A actually same tractor as an A in many ways just designed different to be a "cultivision" There is also a BN-original id plate found on inside tractor support. Overall good little tractor
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
