Re: Will the Cub mower fit a 140...my mistake?
Posted by Haas on September 18, 2004 at 19:08:45 from (12.65.18.159):
In Reply to: Will the Cub mower fit a 140...my mistake? posted by Sandy on September 18, 2004 at 11:36:29:
The Cub mower won't work on the A, Super A, or the 140 for the reasons the others stated. I would not even try the conversion. As Hugh said because the PTO turns opposite, the pitman flywheel will unscrew off the shaft.
Post a Followup
Subject:
