Re: Cam bearings on w-4 or H
Posted by El Toro on September 19, 2004 at 15:25:50 from (64.12.117.22):
In Reply to: Cam bearings on w-4 or H posted by Bob Quale on September 19, 2004 at 14:23:51:
Hi Bob, Your machine shop should've recommended
new cam bearings. Did you have that block cooked?
They usually recommend new bearings when this is done and a new cam too if the lobes are worn.
I always use SAE30 oil in the tractors when used hard in the field, such as plowing or discing. I hate tearing down the engine twice.
My neighbor was watching me pulling my gas tank on a car to replace the fuel pump. He said I wouldn't change that pump. I replied you're not doing the work, I'm the one that would have to pull that tank again and I don't like doing it twice. Good Luck, Hal
Post a Followup
Subject:
