Farmall Tractors Discussion Board
Re: Adding hydraulic fluid on Farmall 560. HELP!!
Posted by Farmall Mitch on November 12, 1999 at 17:20:06 from (24.140.6.154):
In Reply to: Adding hydraulic fluid on Farmall 560. HELP!! posted by gris on November 12, 1999 at 17:14:32:
You take the plate off by the shifter,I think there are 3 bolts.To check the level there is a plug right under the clutch pedal.
Post a Followup
: Re: Re: Adding hydraulic fluid on Farmall 560. HELP!!
