Re: case 580 diesel stalls when warms up
Posted by El Toro on September 20, 2004 at 11:12:06 from (216.148.246.134):
In Reply to: Re: case 580 diesel stalls when warms up posted by El Toro on September 19, 2004 at 15:08:36:
Hi, I think you should remove the battery ground cable and clean it with a wire brush or some emery cloth until it shines. This means you unbolt the ground cable from the tractor and clean the metal surface under the ground strap.
Also clean the clean ground strap lug that bolts to the backhoe. Clean the negative battery terminal, while you have the ground strap disconnected clean the positive terminal on the battery and the positive battery lug. You should
remove the battery cable at the starter solenoid
and clean it too. Reinstall positive battery cables, make sure they're tight and then install
your ground cable to the backhoe and then to the battery. Corrosion is bad on battery cables at times. Hope this helps, Hal
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
