Re: Fast-Hitch service manual
Posted by CNKS on September 20, 2004 at 19:02:10 from (207.178.99.18):
In Reply to: Fast-Hitch service manual posted by BillWV on September 20, 2004 at 09:49:01:
A parts manual will do you more good than anything -- you probably need to disassemble the reservoir and put a kit in it. Easy enough, there are no adjustments in it -- just takes time. Kit is available from Case-IH. Unless you have a photographic memory, you will need the parts manual. Your pump probably needs seals where the pipes attach, good idea to remove it and replace the seal that keeps oil out of the crankcase, you will also need a gasket where it attaches to the block. All this is in the parts manual.
Post a Followup
Subject:
