Re: Removal of cam gear on H
Posted by El Toro on September 23, 2004 at 05:52:36 from (66.119.34.39):
In Reply to: Re: Removal of cam gear on H posted by MagMan on September 23, 2004 at 04:59:20:
Hi Jon, I like using a cutting torch for heating.
You can put the heat where it is needed better.
Be careful and do not squeeze the trigger. I've
never found anything better for removing seized
metal on shafts or rusted nuts. Use cutting oil on those drill bits when trying to drill that timing gear, they will cut better and will keep
the drill bit cool. Hal
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
