Re: 1952 Farmall C Weight
Posted by Stan(VA). on September 23, 2004 at 08:04:35 from (69.19.0.1):
In Reply to: Re: 1952 Farmall C Weight posted by Paul Shuler on September 22, 2004 at 15:53:19:
Paul,
I think something is off here. I have weighed (at tractor pulls) a '51 C (original touch control and PTO) that I installed a fast hitch on at 3100 lbs, and a '52 Super C (230 style hydra touch, PTO, and belt pully) with a Saginaw 3 pnt hitch also at 3100 lbs. Both tractors had just air in the tires (11.2 x 36), no wheel weights (and I subtracted my weight).
The rear weights are 145-150 lbs each, fronts are about 42 lbs each; so one complete set would add 380 lbs. So I could see up to 3500 lbs, but at almost 4500 lbs you've got to have fluid on those tires, or something else we're missing?
Stan(VA).
Post a Followup
Subject:
