Re: 1952 Super C Starting Problem
Posted by captaink on September 23, 2004 at 09:21:33 from (66.115.214.56):
In Reply to: Re: 1952 Super C Starting Problem posted by richflhtc01 on September 23, 2004 at 08:34:07:
I know that you had a shop check the starter, but… Did they try to run the starter under load, or just “free wheel” (no load) test it? A no load test will only show if a starter runs, not if/how it will handle a load. Also, where on the starter housing did you connect the ground cable? I ask because the current flows from the terminal on the top of the starter through the field coils and armature and grounds through the brushes in the end cap of the starter. The end cap of the starter is located on the opposite end of the starter that mounts to the engine block. To test the ground, you should attach the ground cable to the end cap of the starter, which by the way is not an easy task. If this seems to help, check the following mating surfaces: between the end cap and the field housing (middle part of the starter), between the field housing and the drive housing (end that attaches to the block), and between the drive housing and the block. Each surface must make good contact in order for a good ground. If all are polished clean and the bushings are good, check the field coils with an ohm meter and make sure that there is not a current leak from the coils to a ground. You should have practically an infinitive amount of resistance with the starter disassembled between the terminal at the top of the starter and the field housing. If not, then you will need to replace the field coils or possibly the whole starter. Another possibility is that the armature (center shaft with the drive gear) is dragging on the field coil mounts. With the starter apart, look for rubbing marks on the center metal part of the armature. If you see some, then the bushings need to be replaced at a bare minimum, possibly the whole starter. I know there is a lot of info here, if you have questions, post back.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
