Re: 1952 Super C Starting Problem
Posted by Zane(WA) on September 23, 2004 at 11:35:04 from (12.144.139.211):
In Reply to: Re: 1952 Super C Starting Problem posted by richflhtc01 on September 23, 2004 at 08:57:57:
A cracked block wouldn't neccesarily affect conductivity, there would still be other parts of the block to conduct electricity. Might try mounting the ground strap as close to the battery as possible (on any of the battery box hold-downs). Someone mentioned making certain the contacts are clean. Be real careful of using a 12v battery and not crank but a couple of seconds and let it cool off some between attempts. Also the place that checked out the starter for you, they did test it under load, yes? One other thing to possibly check is the starter contact itself. Remove the cover and see if the contacts are clean, they may be carboned or severely pitted. I'm not sure, but I think this is due in part to not pulling on the starter rod enough to make a good and full contact over time. Pretty darn frustrating ain't it ;)
Post a Followup
Subject:
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
