Re: Has anyone broke a seat off of a F-20, F-30 or
Posted by Dave in GA on September 23, 2004 at 14:40:33 from (163.246.18.120):
In Reply to: Has anyone broke a seat off of a F-20, F-30 or Reg posted by Ronsjunklot on September 22, 2004 at 19:26:37:
When I bought my 1936 F-20, the original angle-iron seat support bar had been replaced with a section of leaf spring. It was nicely done, and the leaf was tightly bolted to the seat support mount. It had a nice bounce to it. Then some YT folks advised me to remove the leaf spring immediately and find and install a correct seat support with the coil spring and the long bolt, which I did. The reason is that other Farmalls have had similar modifications done in the past, with a leaf spring used to hold the seat. For whatever reason, leaf springs WILL break, giving the operator a quick ride straight down to the ground, and possibly into an implement, if not saved by the drawbar. I advise you to inspect all of your seat parts to make sure that the bolts are not worn. If they are, replace them. Also, make sure your coil spring is good. I've heard that these can get rusty and weak, and if one breaks and the seat suddenly drops a few inches, it could be enough to knock the operator off the seat.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
