154/cub carb leaking gas
Posted by John in Ct. on September 23, 2004 at 19:09:33 from (192.233.162.175):
I rebuilt the Carb. on my 154 Cub Lo-Boy with the IH kit. I set the float height to 1 13/32" with a float drop of 3/16" just as the specs call for . I measured both with the new gasket in place. It runs good but the carb. still leaks a little gas. Should I maybe set the float/float drop to a different spec? On my old needle and seat, I lapped it in with valve grinding compound and it worked ok. I reinstalled the old needle and seat and that leaks too (a little). Maybe I should re lap it? Thanks!!
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
