Posted by jdemaris on April 03, 2009 at 06:57:06 from (67.142.130.49):
In Reply to: 706 injector pump posted by Bryce on April 02, 2009 at 16:51:55:
Allan is 100% correct. All the rotary injection pumps have their own feed pumps built into the back. In most cases the little pump serves two funcions. Allows fuel to be lifted up to 12 feet, and also operates the fuel-advance.
I've seen 706s with Roosamaster/Stanadyne and also CAVs. CAV was built under license by Stanadyne (they paid to copy it overseas). Same with the rotary German Bosch pumps and Diesel Kiki clones.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
