Re: Calling all Farmall Doctors..
Posted by Jim in NC on September 24, 2004 at 03:42:32 from (172.200.142.218):
In Reply to: Calling all Farmall Doctors.. posted by Robert in NC on September 24, 2004 at 03:33:15:
Try welding a nut or bolt to it if you have enough surface area to get a good weld. You can then use a wrench of your choice on it. I tried this on my brother's super a oil drain plug that was boogered up and it worked well. Good Luck!
Post a Followup
Subject:
