Re: Farmall Axle Swap..............Can I do it?
Posted by Scott Swanson on September 24, 2004 at 11:31:02 from (209.180.31.9):
In Reply to: Re: Farmall Axle Swap..............Can I do it? posted by Dr.EVIL on September 24, 2004 at 11:24:27:
Thanks! I need to hunt up some oil seals and I will be good to go. I am turning the tractor into a movable, drivable, hand crank starting buzz sawing monster. I need to figure out how to hand crank it with a buzz saw mounted on the front though.
Thanks again!
Scott
Post a Followup
Subject:
