Re: M engine numbers
Posted by Guy Fay on September 24, 2004 at 15:58:13 from (12.175.5.133):
In Reply to: M engine numbers posted by Glen E. on September 23, 2004 at 22:37:55:
The BKM is intersting- IH might have put this on replacement blocks for awhile but I thought they were usually blank- a W-6 would have WBKM, a U-6 UBKM, etc. Sometimes the stamp didn't hit square and one letter might not have struck. Sometimes something may have rubbed a letter out. Of course, maybe there was another letter on the tractor that you didn't see. Anyway, the BKM is essentially the type and size of the engine. No signifigance, other than IH was getting a combination of letters they hadn't used before! All of the single and double letter combinations were taken by then. X1 means a gas engine.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
